I've been doing some tuning with my ME chip recently.  Other than an adjustment to the #4 knock disable setting I've yet to use any of the other programming capabilities of the chip.  I'm trying to learn what some of you ME experts are using in terms of data or scan tools (I have Direct Scan) in order to aid in tuning the following:
#3 Power Enrichment
#5 Cruising Fuel
#7 Spool-up curve select
#8 Off idle fuel
I've got the WOT tuning down pat with my EGT meter. My car seems happiest around 1450 EGT. What I'm not sure of is what means I use to tune the above mentioned paramaters? Are there any other chip settings besides those mentioned that I might adjust for improved performance? Thanks.
			#3 Power Enrichment
#5 Cruising Fuel
#8 Off idle fuel
