Max Effort ME-R 16 POS TW
V8killR4U
I have a Max Effort ME-R 16 Pos Thumbwheel. I have 2 chips for 42.5lb injectors 18*-26* (dual timing) I also have chips for 75lb injectors and a chip for ME-R Mafless for 75lb injectors as well.
$150 for the system and chips.
Me-R
Run a MAF with Translator TTchip for 009;s. Now I've seen and have read a lil' about the MER mafless system. Would this be all you would need to convert over to mafless? Clueless about mafless converstion.
To run Mafless your ECM has to be modified for it. Which is around $100 (dont quote me) or if you have a power logger then the ECM does not have to be modified (just plug and play) So essentially you can simply do your self a favor and get the powerlogger and not have to spend $ money to get the ecm modified.
Your PM box is full bro.....can do 150 shipped if that works. Let me know and I will PP you tonight.
Thanks,
Kyle
