Mease DP installed!
GNSteve
EFI Unlimited #4
Hi all,
Finally installed my Mease downpipe today. Removed the stock elbow/downpipe/converter, installed Mease DP and test pipe.
The DP fit perfect. No need to "tweek" any metal or move brackets. I was real happy about that. The DP did come close to the heater box, but there's about an eighth inch of clearance there. I cut the turbo shield to allow the new DP to exit.
Took it out for a little test-run near my house. Low to mid power is much better. Couldn't really test top end power, as my boost actuator has to be turned out a few turns. Boost maxed out at 30psi!:eek: Turns out the pin the rod sits on is at a angle compared to the stocker. I adjusted this already and will be ready for another test tomorrow on the way to work.:D
The pipe is nice, and the fit is very good. The poly motor mounts on my car may have helped this, though.
All in all, a good mod. All I have to do now is get my boost back in line and it'll be all good. Next up: PowerPlate.:D
Hope you guys can make the Anna Millers get-together on the 22nd.
Steve
Sounds good Steve, glad to hear it went in without problems. I was following the posts, and it looks like some people were having fitting problems. Wow!!!! up to 30 pounds?? The stock one must be really restrictive.
