87-TURBO-T
- Apr 16, 2009
so basically, i adjust the pushrod to zero lash, then add about .030 for preload? thanks
SignUp Now!Don't forget to have the rocker lever's adjusting screw at the correct location when doing so.
For example, HS recommends 2 threads below flush from underside of the lever as "optimum". These are .050" per thread. The lifter preload is recommended at .025" ...which is 1/2 of a thread. So when I will measure push rod length I will do so with the adjusting screw protruding 1.5 threads below flush.
That way, during actual installation, after the .025" pre-load is set the adjusting screw will be 2.0 threads below flush...the optimum location for HS rollers.
HTH's,
Bob
