Joined the 11 Sec Club!!!!
Details of the run:
60' 1.74
330' 4.89
1/8 7.51
MPH 91.02
1000' 9.89
1/4 11.92
MPH 114.22
Your Screen Name or Car Number Here 19TTA89 #343
EMPTY WEIGHT:??
BLOCK:Stock
HEADS:Stock
TRANSMISSION:Flaring between 2-3 shift badly...Trans Time!!
TORQUE CONVERTER:12" 2800
DIFFERENTIAL:Stock
INTERCOOLER:Stock
THROTTLE BODY:Stock
RJC POWER PLATE:Yes
INJECTORS:009's
THERMOSTAT:160
TURBOCHARGERt-51
VALVE SPRINGS:LT-1's
MAF:Stock
DOWN PIPE:ATR Stock Replacement
EXHAUST:ATR Catback..With Dump
FUEL PUMP:340
FUEL PRESSURE REGULATOR:Accufab
FUEL PRESSURE:44 Line off
ALCHOHOL INJECTION:no
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:M&H Racemasters305-40-16
AIR BAG(s):none
SCAN TOOL:Scanmaster
FUEL:112
CHIP:Testa
CHIP TIMING:26
KNOCK RETARD:2.8
OXYGEN SENSOR VOLTAGE:812
EXHAUST GAS TEMPERATURE:N/A
TRACK ELEVATION:Not sure....E-Town
TEMPERATURE:56
PEAK BOOST:21-22 Psi
BOOST AT LAUNCH:8psi
MILES ON THE CAR/ENGINE:61,000 About 500 on Engine
Details of the run:
60' 1.74
330' 4.89
1/8 7.51
MPH 91.02
1000' 9.89
1/4 11.92
MPH 114.22
EMPTY WEIGHT:??
BLOCK:Stock
HEADS:Stock
DIFFERENTIAL:Stock
INTERCOOLER:Stock
THROTTLE BODY:Stock
RJC POWER PLATE:Yes
INJECTORS:009's
THERMOSTAT:160
TURBOCHARGERt-51
MAF:Stock
FUEL PUMP:340
NITROUS:no
AIR BAG(s):none
FUEL:112
CHIP:Testa
CHIP TIMING:26
KNOCK RETARD:2.8
TEMPERATURE:56
