Looking for one with the brass fittings as I intend to use this to run methanol (alcohol). It can be the sender delete version, just as long as it has the brass fittings for methanol use.
The top of the tank where the sender goes, is that an open hole in the top of the tank? Or is that a black cover that is surrounded by the bright trim ring?
