methanol pump
  • Thread starter Thread starter sy1765
  • Start date Start date
S
sy1765
Guest
where can i get a pump that will last or is made for meth. i want to run 100% VP M-1 through an alky kit. thanks.
I believe it is Shur-Flo that will give you a pump with seals made for Methanol. Drop Steve Yaklin a note if he does not see this. He has all the details. Cost is about $100 as I recall.
thanks for the reply.
is this pump similar to the one in the SMC kit?
how can i contact steve yaklin?
no, it is an external pump....do a search on his name on this board...he has posted to some topics in this forum recently.
i was accually researcing kits last night and stumbled across joe's kit. the more i look at it, the more i lean toward getting it instead of the smc kit.
You will love the Tripodi kit!!! I've had mine for a year now. The product quality is top notch and Joe one of the most helpful guys I've dealt with. He even called and faxed from work to get me straigtened out. I'm running 24psi and 26* timing with a PTE-44, V4 and 009s. Last year it went 11.80@116 in hellish weather on 22-23psi and drag radials. His pump already comes coated for methanol, although I've only run denatured so far.
Steve Y will probably recommend the FloJet, you'll need a special one for Methanol though, and it aint cheap. Search the yellow pages for SCC pumps in chicago, they are one of the only dealers of said pump.
