Oct 10, 2019 #1 N nwarky Active Member Joined Jul 7, 2003 Messages 603 As the title states, is there a way to make sure that the 30+ year old antenna wire on our Turbo Regals is still in usable condition? (Yes, I am referring to bench testing.) Thanks for sharing your knowledge! Dean
May 10, 2020 #2 garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Messages 4,336 Should show zero ohms from radio end (center conductor) to the mast. From the center pin to shield) should NOT show continuity.
May 16, 2020 #3 N nwarky Active Member Joined Jul 7, 2003 Messages 603 garyk1970 said: Should show zero ohms from radio end (center conductor) to the mast. From the center pin to shield) should NOT show continuity. Click to expand... Gary, Thanks for the help. Simple enough.
