Mexico replacement 350 motors
Sal Lubrano
Does anyone know where to find a replacement oil pan for these motors. These motors were replacements for many vehicles so they have provisions for the dipstick tube on both sides of the motor. I need a pan which will work with this motor. The casting is 10066036. I am having no luck.
My engine Casting is 10066038. I just looked at the engine. There is a hole on the starter side of the engine (at the bottom of the block) that looks like a spot for a dipstick. On the other side of the block, the hole for the dipstick tube is cast into the block. I used a Moroso pan with the dipstick on the side opposite the starter (early style) and the pan and gasket blocked the hole at the base of the starter side of the block. Does that make sense to you? I can get an oil pan part number for you. Mine is a trap door pan that kicks out and has clearance for a SB400 crank.
i think any 2 piece rear main seal oil pan will work. the gasket blocks the hole on whichever side doesn't get a dipstick.
