Mice!! I hates em
Just had my first experience with those damn mice. They chewed-up my Chevy Blazer's engine pretty good in just one night. Even chewed the spark plug wire right down to the wire core. Did realize it happened for a day or so until I kept finding more and more damage. Could see the little bastard's teeth marks on the solid plastic neg battery terminal. Too bad he didn't fry himself on the battery. Thankfully he didn't get to the GN.
The traps are set now!
Open and close the doors and open the hood and trunk lid, every night. I put standard snap traps in the car, in trunk and on floors, with small dabs of peanut butter - works great. Also keep a fox terrier in the garage at night. He will alert me if a mouse is present. :)
I use that mouse killer it comes in a poptart looking bag full of little green pellets.the mice eat it and then leave the area in search of water.I also use pb on snapper traps.I have a electronic gizmo that plugs in and it doesnt work a crap.Kill em all and keep them away from all GN's.
Just saw this in an e-mail that was sent to my wife; might help with the mice problem and has other uses:
"Bounce" this around
> And all this time you've just been putting Bounce in the dryer!
> It will chase ants away when you lay a sheet near them.
> It also repels mice.. spread them around foundation areas, or in trailers
>or cars that are sitting and it keeps mice from entering your vehicle.
> It takes the odor out of books and photo albums that don't get opened too
>often.
> Repels mosquitoes. Tie a sheet of Bounce through a belt loop when
>outdoors during mosquito season.
> Eliminates static electricity from your television (or computer) screen.
> Since Bounce is designed to help eliminate static cling, wipe your
>television screen with a used sheet! of Bounce to keep dust from resettling.
> Dissolve soap scum from shower doors. Clean with a sheet of Bounce.
> Freshen the air in your home. Place an individual sheet of Bounce in a
>drawer or hang in the closet.
> Put Bounce sheet in vacuum cleaner.
> Prevent thread from tangling. Run a threaded needle through sheet of
>Bounce before beginning to sew. Prevent musty suitcases. Place an
>individual sheet of Bounce inside empty luggage before storing.
> Freshen the air in your car. Place a sheet of Bounce under the front
>seat.
> Clean baked-on foods from a cooking pan. Put a sheet in a pan, fill with
>water, let sit overnight, and! sponge clean. The antistatic agent apparently
>weakens the bond between the food.
> Eliminate odors in wastebaskets. Place a sheet of Bounce at the bottom of
>the wastebasket.
> Collect cat hair. Rubbing the area with a sheet of Bounce will
>magnetically attract all the loose hairs!
> Eliminate static electricity from Venetian blinds. Wipe the blinds with a
>sheet of Bounce to prevent dust from resettling.
> Wipe up sawdust from drilling or sand papering. A used sheet of Bounce
>will collect sawdust like a tack! cloth.
> Eliminate odors in dirty laundry. Place an individual sheet of Bounce at
>the bottom of a laundry bag or! hamper.
> Deodorize shoes or sneakers. Place a sheet of Bounce in your shoes or
>sneakers overnight.
> Golfers put a Bounce sheet in their back pocket to keep the bees away.
> Put a Bounce sheet in your sleeping bag and tent before folding and
>storing them. Keeps them smelling fresh.
How about one of those plastic bubbles that compleatly seals the floor & around the whole car?.
I have seen a GNX on Ebay that was stored with this system.
LMAO, yep Jesse, does look that way on the surface.
Anyway you can kill a mouse, do it. The last GM dealer I was at was having houses built right behind it. Needless to say, the displaced mice found an abundance of food in the form of leather seats and wiring on a bunch of new Buicks, Olds, and GMC/Chevy trucks. I hated to see a lot porter pull a truck into the service drive an anounce the SES light was on. Needless to say, our insurance carrier hated it even more.
Mark :D :D :D
