mid 11 - mid 12 second cars... what plug gap?
Vendor Defendor
Out the window
this is a question is for those running anything between mid 11's to mid 12's
i was wondering what kind of gap you are running on your plugs?
i am currently running the NGK UR5's gapped at .035 some one said to take the gap down a smigget to .032
good idea? or what do you recommend?
thanks
I'm running NGK UR5's with a tight 0.35 gap. When I say tight, I mean that the .035" feeler gauge will only slide into the gap if I force it a little bit.
Car runs around 116mph in the quarter with 22-24psi boost.
I have had a Modern Muscle/Ramchargers high output coil pack on the car since I bought it. I don't know if that's helping or not, as I've never run it with a stock coil pack.
Good luck,
