evil mechanic
- May 14, 2010
So I might be trading a bike i built for a 87 Regal Limited Turbo. I hear there was only 1035 made.
The car is black and still has all the chrome on the exterior so the outside is unmolested i guess? The interior has new carpet, new floor mats, 87 GN front and rear seats. Still colum shift, but he has a GN console to go with the car. power antenna still works.
Here is the mod list according to him:
Complete rebuilt motor with TRW replacement forged pistons, stage I cam, Fererra valves, T&D shaft rockers, Champion valve covers, new fly-wheel.
Mods include: gt6157e precision turbo, Terry Houston 3" S.S down-pipe, Flow-Master dual exhaust system (SOUNDS AWSOME), turbo tweak chip, motron 60 injectors, adjustable waste gate & fuel regulator, Walbro fuel pump, 3" chrome inlet pipe with cold air kit/K&N, H.D cooler hoses, H.D aluminum radiator, smc alcohal injection kit.
Every sensor replaced with new GM after motor was installed. New Delco battery/cables.
Precision 9/11 L/U converter, shift-kit, Art Carr deep trans pan,
Factory 8.5" posi with 3.42 gears,
New front end suspension (Billstein shocks/springs tierods etc).
Factory T-Tops, Digital dash (new upgraded 195 mph unit from Caspers Electronics)
Car currently has 87 GN front/rear seats,
New carpet & floor mats, column shift, but has a GN console to go with car. Power antenna still works perfect
Rear GNX seat braces, front end upper & lower braces (CAR IS TIGHT)
Needs a heater core(currently by-passed)
Runs excellent, very reliable and fast, 11 second car you can Drive anywhere, and can easily be made a lot faster. bigger rear wheel cyls, rebuilt the powermaster brake unit, brand new rjc racing plenum with power plate kit with a accufab 70mm throttle body, hotwire kit for fuel pump.
He says far as he knows, its the matching motor.
I can post up pics when im allowed to. i guess 10 posts??
Anyway whats this car worth generally? If it doesnt fit me (im an import guy) then i might just sell it.
Aaron
Aaron
