milled heads/pushrod length???
87-TURBO-T
i just found out that a set of heads i bought have been milled roughly .020-.030. will stock pushrod length be ok?
I doubt it. Stock rocker shafts or roller rockers? From the factory ive seen stock engines with .050 of preload.:eek: You don't want to bottom out the plunger in the lifter. You would have big problems. For piece of mind I would definetly check it.
If you want to know for sure I have a adjustable pushrod you can use if you want to. I could mail it out. As long as I get it back:D
that would be great!!! sending you a pm.
