Originally posted by six appeal
would the pushrods be affected by milled heads? depending on how much the heads were milled would longer pushrods be needed or would the stock ones be fine [/QUOTE
The pushrod length could possibly be affected , depending on much milling was done, Im working on that situaton right now, I used single shim head gasket, and my lifter preload is .070 which is a bit to much , so im looking into getting pushrods that are .035 shorter to give me the proper lifter preload. or im looking into shimming the T.A rocker shafts. the answer to your question depends on what your lifter preload is
