Well me and jadams want out tonight to test the car with some slicks and new reducer, the car was flying and spinning the slicks all the way down the road. I stoped and heated the tire because they were a little hard from setting and it started to back fire some.
I let off and my oil light came on for a min then want away, i stoped up the road and it was mising bad and found 20psi on fuel press, out of cam2 i guess. Stoped and put gas in and it ran fine, tell about 3 miles down the road then it started to mis again when i would tap the gas. The car dies at idle if i touch the gas at all.
What now, it seems to run fine when it cools down but when it heats up it starts all this crap, could it be the o2 sensor and make it run that bad. Or will exhust leaks do this.
