Squid4life
- Jul 5, 2004
Rad hold down from a non-GN. Works if you run after market fans, not the stocker. Much cleaner looking since you don't have the extra tabs for the stock fan. $30+ ship
87 GN alt. Needs rebuild. Charges but had a slight flicker when under lots of electrical load. Painted silver and black. $28 shipped anywhere in 48.
Misc box #1: rockers, 85 pos battery cable, 85 vac can, pass fenderwell bracket for solenoids, 2 bar MAP, fuel filter with about 20 miles on it, 87 PS bracket, 85 hard fuel lines for front, 85 turbo bracket and coolant lines, 87 air intake elbow, 85 throttle cable, 85 trans dipstick tube, heater selector valve, a few 85 misc brackets. $35 shipped in 48
Misc box #2: all the misc brackets, started nose cone, etc on the floor in the pic. $20 shipped also includes the front sway bar U brackets with polyurethane bushings.
Misc box #3: all of the misc nuts, bolts, tensioner parts, timing pointers, oil slingers, rocker bolt sets, used non-tty headbolts, flex plate bolts, etc, etc. $25 shipped.
Powdercoated GN mirror for the passengers side. Got it in trade and ended up not needing it. very nice finish, can be polished to a luster as well.
$25 shipped.
Also have the radiator out of my 85 GN, in perfect shape I just switched to an F body rad. $30 + shipping. Can get pics later if need be.
And last but not least an aftermarket rear sway bar for the GNs. It can't be used with boxed control arms, as it mounts inside the arms. It is a bit larger diameter than the stocker. Worked great, but needed boxed arms more than the sway bar. I kind of miss it though...) Can get pics later too.
$30 + shipping.
$25 shipped.
$30 + shipping.
