Looking at the Intercooler... Do you know if that would fit in an 84 GN?
I'm sure it would fit with some additional piping, I'm sure that someone with a "Hot-Air" wouuld know the exact additional pieces of piping that would be needed.
SignUp Now!Looking at the Intercooler... Do you know if that would fit in an 84 GN?
Will you take $110 shipped for both the chrome 3" inlet air pipe & alternator cover? Thanks -Tim
KB FMIC w/chrome up pipe. Has a Blow off valve. Comes with all hoses and clamps etc. Have pics that show where and how everything hooks up.
$325.00 Shipped
Modified stock turbo shield.................... just painted with 1200 degree paint.
$35.00 Shipped
55lb Injectors with 4 different Chips for these injectors. 1 TT Chip and 3 Quad Air Chips (2 of which were never used)
$200.00 Shipped[/B]....."can seperate chips and injectors"
Coolant Resivoirs and Washer Fluid Tank
$25.00 each Shipped
Stock Vacuum Block & Gasket
$20.00 Shipped
ATR Air Canister & K&N Filter (Canister modified "on the Bottom side" to flow more air).
$50.00 Shipped
If anything seems unreasonable then make an offer...............Thanks
1 : KB FMIC w/chrome up pipe. Has a Blow off valve. Comes with all hoses and clamps etc. Have pics that show where and how everything hooks up.
$325.00 Shipped
2 : Modified stock turbo shield.................... just painted with 1200 degree paint.
$35.00 Shipped
4 : 55lb Injectors with 4 different Chips for these injectors. 1 TT Chip and 3 Quad Air Chips (2 of which were never used)
$200.00 Shipped
"INJECTORS are Low Impedence, Your ECM will need to be modified".....Will sell injectors seperately........$125.00 for the set of injectors..............chips sold seperately for $30.00 each or all 4 for $100.00
5 : Coolant Resivoirs and Washer Fluid Tank
$25.00 each Shipped
7 : Stock Vacuum Block & Gasket
$20.00 Shipped
8 : ATR Air Canister & K&N Filter (Canister modified to flow more air).
$50.00 Shipped
I'll take the Turbo heat shield. pbs01@att.net
Someone else mailed about the shield right before you did. If they do not get it I'll let you know............................Thanks
Will the injectors work with a stock ECM??
Audie,
I am interested in the two coolant overflow jugs for $50 shipped. Are they cracked in any way. Do they leak? I live in Canada I will pm you my address because shipping could be a little more. We can work that out. USPS is the best way. Thanks Dave
$275.00 Shipped
$175.00 Shipped
$25.00 each Shipped
$20.00 Shipped
12 : ATR Air Canister & K&N Filter (Canister modified to flow more air).
$50.00 Shipped
Money via PayPal sent for coolant overflow tank. Thanks Dave
