DarthBuick
I Win even in your dreams.
- Dec 22, 2014
Last Saturday on my way home my car started to miss at red lights but only a few seconds and smoothed out. About the time I got home 10 miles later the miss was constant it felt like it was hitting on four cylinders and it died when idling in garage. At first it didn't want to restart and it backfired out exhaust. I let it sit for 30 minutes and it started up but started missing after a couple of minutes. I used my infrared thermometer cylinder 2 and 6 was about100 degrees cooler than the other four.
Things I have tried so far
I swapped out # 2 and 6 plug wires with other cylinders and it made no change
I unplugged the cam sensor after starting and no change.
I OHM the coil pack and it checked OK
I check ground wires and they seemed OK
I checked the spark on # 2and 6 and it looked good
There is no codes stored so I was wondering if it sounded like ignition module or crank sensor. I am open to ideas Thanks
