89mulletbird
- Jun 24, 2004
I started backfiring the other day under 10+ psi, then after awhile the backfire stopped but it felt like it was only running on 5.
I parked it and didn't look at anything, figured I'd just put new plugs in. When I went to install the new plugs, I saw #1 plug wire was off. I changed the plugs and put everything back together, but it is still running like it's on 5 cylinders. Doesn't feel smooth under load.
My 02's are normal, 800 at WOT.
My plug wires are only a couple thousand miles old, what else should I check out?
 or just a bad coil pack ... ya have to just start checkin junk
