turboman38
It costs money to go fast
- Aug 1, 2001
I've had a missing problem for around a year. I've replaced the coil pack,module,MAF,O2,Crank Sensor,Wires and plugs. I've also tried to eliminate any vacuum leaks. It happens under light load at a steady speed, especially in the lower RPM range. Car runs great when you mash the gas. Anybody have any idea what this could be?
Can a coil pack be bad in the lower RPM range and be ok in the upper range?
Could the wiring harness be bad somewhere?
Could an old positive side battery be the problem?
Any help and suggestions are appreciated.
