May 18, 2004 #1 F fatride Senior Member Joined Aug 13, 2001 Messages 1,947 Is it ok to use Mystery Marvell oil with denatured alky for a lubricant?
May 19, 2004 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,968 M.M. oil doesn't mix nearly as well as the Klotz lube. Used both. I'd buy a quart of the stuff from Steve, or locally if you can find it, and it will last a long time. Worth it in MHO.
May 19, 2004 #3 G gokada New Member Joined Nov 9, 2001 Messages 488 Were do you get this Klotz lube?????
May 19, 2004 #4 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,968 Steve C. of the SMC alky. kit fame.
May 19, 2004 #5 1 19gn87 New Member Joined Aug 25, 2002 Messages 356 Also some motorcycle dealers? or Klotz
