I ask because my sensor isn't as smooth anymore. It used to show like 170 or so all the time, and when under heavy acceleration and deceleration, the temp would go up a little, then eventuall settle back down again as it cooled. Now it's kind of weird. One moment it's 167, and under no real load, just normal driving, in 15 seconds it'll be 175, then gradually go down to say 170, then 167, then 171 after a few seconds. It's not only not as gradual any more, but it shows odd temperatures when it shouldnt. I have a ton of data logged in my head for coolant temps, because I'm obsessed with coolant temps, and I know these temps are not at the right times. It's like the sensor reads 15 seconds slow or something. When it should be hot, it's 167, and when it should be 167-170, it's like 180. It's the exact opposite of when it should be happening. I thought I'd ask because even though the numbers are only about 10 degrees off at times, it's still not right, so I had to check. I'm going to re-do my S hose, thermostat housing water pump, and coolant sensor. We'll see what that does.
