Modified ecm,TT chip, injectors, fuel rail, afpr, 3 bar map sensor, spacer, etc.
WeSS
I gotz 2 sub woofers
Modified peak and hold driver acxa GN ecm with proper cal pac, Eric Marchall turbo tweak 72 lb alcohol chip, Stock gn fuel rail with 72lb injectors(installed and ran for 5 minutes), accufab black adjustable fuel pressure regulator tapped with an fitting, xrp stainless braided lines to champion spacer plate, boost line and 3 bar map also fitted this way. Have one used gm plenum gasket and have one brand new in the package gm plenum gasket. Also made a vacuum block block off plate with screws. You pull your vacuum off the spacer shown in pictures. This allows for removal of ugly vacuum block and steel vacuum lines. Stainless button head bolts for spacer to be used with intake manifold. Racetronix heavy duty injector harness with relay hotwire. Also have xrp T that was tapped into intake manifold for pcv. ATR heavy duty checkvalve used in conjunction with stock delco pcv. The other end of T was for vacuum brakes. Will sell combo for $750.00 shipped. Paypal accepted. You pay 3% fees.
I would like to buy the spacer and SS/lines if you seperate.
BTW,
Got the gasket.
Bo
parts
BTW,
Got the gasket.
Bo
Bo pm an offer.
Here goes. 72lb siemens/deka injectors installed and ran long enough to move car in the yard. Basically brand new. $300.00 shipped
Turbo Tweak chip version 5.6, 2345 72# alcohol 24/22 degree 24-27 psi $75.00 shipped
ACXA 1227148 GN ecm modified 6/07 for high & low impedance injectors $150.00 shipped
Above trio for $500.00 shipped
Accufab adjustable fuel pressure regulator $100.00 shipped
Stock gn fuel rail $50.00 shipped
Racetronix heavy duty injector harness with hotwire relay $60.00 shipped
Gm 3 bar map sensor fitted with ferrel and compression fitting. Ran to plenum spacer with XRP braided lines adapted to champion plenum spacer with a/n fittings. Also have fuel pressure and boost gauge fitted to spacer via a/n fittings and xrp braided lines. $125.00 shipped.
Add 3% for paypal. Reasonable offers considered.
modified ecm
I'll take the modified ecm. tell me where to send the money order.
parts
ecm sold to windmill.
turbogta1 you have dibs on everything you inquired on but the ecm. Thanks guys.
parts
Here goes. Matched set of 72lb siemens/deka injectors installed and ran long enough to move car in the yard. Basically brand new. $300.00 shipped. Sale pending.
Turbo Tweak chip version 5.6, 2345 72# alcohol 24/22 degree 24-27 psi $75.00 shipped. Still available.
ACXA 1227148 GN ecm modified 6/07 for high & low impedance injectors $150.00 shipped. SOLD!
Black Accufab adjustable fuel pressure regulator $100.00 shipped. Still available.
Stock gn fuel rail $50.00 shipped. Still available.
Racetronix heavy duty injector harness with hotwire relay $60.00 shipped. Still available.
Gm 3 bar map sensor fitted with ferrel and compression fitting. Ran to plenum spacer with XRP braided lines adapted to champion plenum spacer with a/n fittings. Also have fuel pressure and boost gauge fitted to spacer via a/n fittings and xrp braided lines. Throttle body block off plate polished with screws. $125.00 shipped. Still available.
I will take it. I will paypal you. Consider it sold.
Bo
parts
Ecm, chip, injectors sold to windmill.
Spacer plate, braided lines, fittings,3 bar map sensor etc. sold to Bo.
