R rw87tt Member Joined Oct 21, 2006 Dec 25, 2010 #1 I will be doing A front end rebuild on my car. Would it be a good idea to replace the control arm shaft with these off set shafts? It's suppose to give you more positive camber. The ones I have are kind of beat up. Thanks
M mousemobile Member Joined Mar 13, 2003 Jan 10, 2011 #2 It is a fix for when you can't the right amount camber using the stock control arm shafts. If you end needing too many shims, the Moog part will work. If you plan on adding about a degree more camber, then go for it!
