SignUp Now!Ok Ok ready for more boost, is 9 psi the max for a carbed turbo setup?What is the max that has been seen and how do i acheive this..
I don't Jim. Look at the update on the turbo BTW. If you gather the parts you can get about 10 lbs more per minute so better spool and less heat in the mix. Another option I thought about is using a nitrous carb spray plate to get more alky in it and atomize better.
so the stock 4barrell can supply enough fuel for 15-20 psi??? as long as the knock is monitored of course....
So at the momement are u running more boost than 9psi with a carbed setup or is it still in the works?
You guys need to stop talking about improving carb'ed turbo cars. Its not fair that I don't have one. There's no experimenting with the IC cars. Tune and go. I wanna play too:biggrin: I think I'm just having boost issues
I just dont see ever going over 10psi:frown: with the small turbo these units are.Now that 301 turbo setup mod That charlief1 is hooking up looks real good cant wait till it is tested and for sale.Ill be glad to also try it out on my setup with no problem at all to see what it is built on...
You're just jealous Jesse.:tongue: I know you want another one but you went and bought an SFI car.:biggrin: Maybe one will show up soon for you.
I'll make you an interesting offer Jim. If you play nicely (lol) you may just be able to try it for a very short time.:biggrin: I'll seriously think about it. Which intake do you have on the car right now? That's gonna determine several things. I've got the 81 that I've been using for the pics and I haven't gotten into the 83 housings or intake yet, but it's the one I'll be using when I get it torn down.
just because you have a bigger turbo doesn't mean you are going to be able to run more boost. The carb turbos have no way of dissapaiting heat, so you need the octane/water to fuel and cool it...in a nutshell anyway. The stocker is fine for now. Should be able to hit a stock IC car quarter mile time with minimal mods and alky injection.
i went as far as 15lbs..... on the orange Luv before i popped a head gasket. (its out for expirments!) The first turbo engine I built in my Blue Luv made it to 11 before the bottom end fell out.
Mind you, this was all on a Holley and MSD BTM. I dont trust quadratoilets or the factory retard.
I would say that it should be easy to get to atleast 20lbs out of it... but ONLY with alky....
A.j.
