ChrisCairns
Senior Member
- May 24, 2001
Okay, I got the center support back out of the case. I then removed the direct drum also, in order to bench fit the center support into it. Fits fine.
I then put the center support back into the case without the direct drum/forward clutches in place and not only does it fit fine but I can even smoothly turn it by hand to line up the bolt holes.
Yet if I try to put the center support back into the case with the direct drum in place it won't go in unless I smack the crap out of it with a hammer .... and I don't think that's correct (duh.) And it's so tight I'd never be able to turn it by hand.
What can be misaligned, preventing a smooth insertion of the center support?
Thanks.
Thanks.
