more hot air parts for sale. turbos, wastegates, intakes
tb3
elbows & a$$holes
getting close to getting everything cleared out of storage. here are pics and prices.
stock turbo. has a bad seal and shaft playl. needs to be rebuilt. i'll include a rear mounting bracket for free. $65 shipped
stock turbo. was working fine till pulled. seal is good. lots of shaft play, turbo is very clean and spins nice and free. i'll include the stock powder coated elbow thats also pictured. i'll include a rear mounting bracket for free. $95 shipped
i have 3 turbo to intake adapters. one has a chip out of it on the intake side. any machine shop can easily fix. i'll take $25 shipped each. whoever buys the first one gets the chipped one for free.
3 oil drainback tubes. $20 shipped, each
stock 2 groove powder coated water pump pulley. $25 shipped. i'll throw in a stock crank pulley free.
i'll throw in another crank pulley for free if anybody buys something else.
egr delete with plug for the intake. $20 shipped
3 turbo/uppipe flange/gaskets. $15 shipped each
3 stock y vac t's with calibrated orifice for wastegate. $10 shipped each
1 stock unmodded wastegate. no leaks, works perfect. $25 shipped
3 wastegates with adjustable rod. one has the only one port. all work great, no leaks. $15 shipped each
stock clean alternator. worked fine when removed from car. pulley fan is in excellent shape. $40 shipped.
2 stock intakes. $40 shipped, each.
1 stock intake with egr hump ground out. $30 shipped
1 brand new still in plastic, intake power 6 emblem. $35 shipped
if you want more of one item, email me and i'll give you a adjusted discounted price. i will combine shipping and start discounting price on stuff the more items you buy
I will take one two hose adjustable wastegate. PM me with shipping and will send payment. Thanks- Brad
$25 shipped for the wastegate and drain tube brad. I'll pm you. I do take paypal goodboy77. I'll pm you
sold so far:
all the adj wastegates and 2 of the orifice vac y's
the $65 turbo
all the oil drain tubes
one of the up pipe to turbo flange
i'm dropping the price of the remaining turbo to $80 shipped. thats includes the stock elbow
i'll cut down the price abit if your wanting more than one part
osolo, you want to do $35 for all three? i'll pm you
area51 motors, i'll pm you on the turbo
ok, heres pics of everything i have left.
3 intakes. couple of powder coated water necks, some tb heat lines. stock heater hard lines, i have one throttle body left. also a bracket. a whold bunch of egr, wastegate, soenoids with mounting plates. the top part of a stock air box, and the elbow. some ac brackets, couple stock air intake tubes. 3 power steering pumps with mounting brackets. a cruise control cable. ac lines in real nice shape. stock wastegate with orifice y. powder coated coil bracket. couple egrs with tubes. 2 nice condition heater cores, no leaks. 2 alt/ac brackets. one is a na to do the 140 amp conversion, the other is a stocker. a fuel rail feed and return line (not pictured), in very nice shape. filter bracket is included. a oil dipstick and tube, 2 trans dipsticks. egr delete. 2 very nice condition ac/header heat shields and brackets. 2 groove water pump pulley and a stock crank pulley. stock 90 amp alternator. also have a stock down pipe, 2 stock uppipes. one has header wrap on it. a stock driver header that has been blasted and painted with vht ceramic paint. a pass stock header that has been blasted and painted with black vht paint. i also have a wiring harness that looks to be complete. i will throw in another wiring harness in with it that has been chopped off before the ecm.
make me offers on this stuff
the modded intake is sold.
i also just found a powder coated ac box heat shield, and a driver side power seat and track from a 84 gn. works fine. i actually have 2 of those.
just make reasonable offers on any of this stuff
heres all i have left. the only thing not pictured is a throttle cable (those are specific to ha cars)
powder coated crank pulley
powder coated 2 groove water pump pulley. i seem to remember this being heavier. i am going to weigh it on the scale tommorow and post up.
2 ac heat shields. excellent shape
2 alt brackets. one is stock, the other is a na for 140 amp upgrade. both like new
powder coated coil/ig module bracket. like new
like new egr and egr tube and base
3 good ps pumps. all three come with brackets
egr delete plate. like new
very nice shape intake tube. no cracks
stock filter airbox top piece with plastic elbow
grey powder coated water neck with 160 thermostat
4 egr/wastegate solenoids with mounting plates.
stock intake. excellent shape
stock up and down pipe. not damaged or anything. just need cleaned up
stock headers. both are very very nice. no cracks and flanges lay flat. all heat shields still intact. i had glass bead blasted them and painted with vht paint. (one silver the other is vht black). they are clean as new and ready to bolt on.
very clean low mile complete fuel rail feed
turbo/intake adapter
make offers
the double groove water pump pulley weighs 1.90 lbs. wish i had a stock 3 groove to compare weight
bumpity bump, all above parts are still available. make offers
do you have the intake emblem still??
any of those vacuum Y's left? i'll take one of each if still around... im also looking for a dipstick and tube if you got em!!! Paypal waiting!
please Email me: racemybuick@yahoo.com
John
