more hot air parts for sale. turbos, wastegates, intakes
intake emblem, vac y's, and dipsticks and tubes are all gone. sorry
the headers are as about as nice example that you'll find. the driver side has been welded, and was welded correctly while bolted to a jig, so the flange lays completely flat all the way across. the outside of all the header ports where reinforced also. i guess i shouldn't say "never", but i seriously doubt this header will ever crack again, short of getting ran over by a tank. the crossover mounting flange is also perfect.
how about $85 shipped for both?
i'll pm you on the water neck.
the headers, egr/wastegate solenoids, and ac heat shields are sold
updated list. what is in pics is what is left. i have 6 of the stock valve cover bolts that have the studs on them. those are hot air specific btw. 3 of them still have the spark plug holders on them.
also have a complete relay and harness that caspers makes that takes care of the smaller wire to ignition module problem in the 84-86 cars. i upgraded it by wiring it direct from my 84 harness to the 86/87 ignition module that i had converted to. so if you've converted, or have been wanting to convert to the 86/87 ignition module, and want to save lots of $$$ and have alot less wiring mess in the engine compartment... then here you go. simply color match the 7 or 8 wires to your existing 84/85 harness, splice them in, and your done.
i'll take $35 shipped for it. if you buy the adapter and relay hot wire kit from caspers, i think its around $150 or so, plus you've got alot more wires cluttering up.
the ac/alt bracket that is left is for a stock 84/85 turbobuick
still have 3 ps pumps. up and downpipe in decent condition. very nice intake. very nice fuel send/return lines. very nice egr setup and a egr delete plate also. powder coated 2 groove water pump pulley. turbo to intake adapter.
make offers
all parts from above post are still available except for 2 valve cover bolts. make offers. I know this stuff isn't worth much.
also have a brand new 84 vac hose and emmision label that's been resized rhe same size as the 87 ones so it can be put on ac box like the 86/7s.
$45 shipped.
surely there's gotta be something else you want from the list too :)
Hows $150 for everything :D?
I'll do 150 for everything. we may be looking at 40-50 dollars for shipping though. the three ps pumps ar what would make it heavy. probably looking at 3 boxes total. I pack well. pm me your address if still interested.
still available.
also have 2 hot air (not 109) blocks for free. both are standard bore. one is the 14 bolt, the other is the 20 bolt. come pick them up.
also have a set of stock 8445 heads i'll take $40 for them
also have a very very low mile 14 bolt timing cover. (almost no wear at the cam button area) this cover has been gone through and all factory slag taken out. a brand new set of oil pump gears installed and all the mods in earl browns write up has been done. only has about 300 miles on it. oil pump has been left on. this is all ready to bolt on and go. again, this is for a 14 bolt oil pan block.
i also have a very nice (no dents) 14 bolt oil pan (with baffle), included will be a like new oil pickup factory style pick up tube.
make offers
pmd you charlie,
both blocks are gone. timing cover, oil pan, egr delete, both fuel send/return lines are sold.
