Get real close to .4 at idle, and over 3.9 at WOT and go on to something else.
You do want to make sure the butterfly is fully opening. While idle was fine on mine, it took a fair amount of grinding to get the butterfly to open fully.
If you change the butterfly's full open point remember to check the TV cable adjustment when your done. Might take a couple of careful measurements to see where the new linkage location is compared to that old, being picky to do that but if you know all the measurements before hand, and where you are afterward to can 2x check to make sure things are ok, if you have to change much.
