Stage II heads, .600 lift 240 @ 50 duration roller cam. I'm thinking 260 on the seat and around 700 on the nose. Dan @ precision says at least 750 on the nose. I'm having a problem with valve float at 7500. I'm running triple springs with OD of 1.645. I didn't have this problem with the old Champion heads with alot less spring size wise. I plan on pulling these off the Stage II heads and measuring them, but I can't imagine them not working. Any suggestions on geting a spring that measure 250 at 2.0 installed and around 750 at 1.4?? As in part numbers or vendors. Last trip out I also noticed my boost not wanting to go past 26 pounds, but I didn't get tocheck that out very well. May or may not be related to the valve float problem.
Greg Kring
9.29@149.5
Greg Kring
9.29@149.5
