more parts
gmgearhead
shifter cable......40.00
shifter....20.00
turbo tweak race chip..50#...110 octane 27/25deg 25psi....40.00
ac comp bracket....25.00
oil dip stick....25.00
oil dip stick tube...25.00....buy the stick and get both for 40.00
brass oil feed t....15.00
fuel lines from frame to fuel rail.....50.00
CV Products chromemolly pushrods .080 wall 8.650 long....50.00
ARP head bolts..only used to bolt heads on....50.00
stock motor mounts fairly new...20.00
heated o2 sensor conversion kit with sensor....75.00
oil pump and gasket shims and new plate....50.00
Jegs liquid filled fuel pressure guage great for under hood hook up to fuel rail..35.00
3 t-bolt clamps..2.5,3,3.5"...12.00
throttle,kickdown brkt.....10.00
washer bottle....15.00
Do not buy anything from this theif!!! Consider yourselves warned. I bought an a/c box described as complete & very good condition with no cracks. I even had a picture!!! He removed all the guts & sent me a broken shell in peices, then left me negative feedback because I communicated with him through pm's asking for my money back!!!! He says I expect too much!!!! I expect the sh!t in the damn picture you tool!!!!:mad:
John Plog
WOW!!! Thanks John. I'll stay away. :D
John Plog
