motor and other misc parts for sale
limitedv6
Stage 11 in the work's
109 motor std bore 010-010 crank and factory pistons no cam but has front cover balancer and flywheel $850 obo
1 stock turbo crank 010-010 but will need turned on the mains will clean up with a cut of 010 $150.00 obo
1 set of arp head bolts for iron heads 40.00
1 BRF tranny (THE VALVE BODY WAS SWAPPED) the tranny is a core 150.00
1 set of 86-87 stock headers these have been repaired and will need to be rewelded comes with crossover 125.00 obo
1 set of 86-87 headers without the crossover these have been repaired and will need to be rewelded 75.00 obo
4 starter heat shields 20.00 shipped
5 tranny dust covers 25.00
1 stock turbo crank has had 1 journal welded on but is ready to go it is 010-010 150.00 obo
I need a few parts if you have them I will take them in on trade
1 peice of -12 braided line 1-2 foot long
1 remote filter houising or turbo saver
1 14 bolt oil pan
1 of the small starters (lt1)
Location?
'87 Turbo T w/E85, 224/224, ported iron heads and intake, 80 lbs injector, TE45A, GEN II, TT and EXTENDER EXTREME G, XP Double pumper and something secret, 86 T-TYPE (Kenne Bell test car) and '11 Tundra Limited Sent from my iPhone using Turbobuick
ky 75 miles north of bowling green I will drive a little ways to meet someone thanks
3 stock starters 25.00 ea shipping will be high on these due to the weight
1 set of lower control arms (stock)
1 set of upper control arms (stock)
I will box these in if you want them boxed for 30.00 exchange
front upper A arms 50.00 obo
front lower control arms 50.00 obo
moser 28 spline axles 1 was warped a little it looked like a bent wheel but after i started looking further into it I found it was the axle. I think you could run them the way they are the only way I found out was from someone following the car and told me if not for that they would still be in the car. They have 1/2 in long studs in them 75.00
2 set's of quarter windows (black)
