The injectors are stock ones I got from Chuck around June or July. Do I need to soak them?
Where can I find a noid light?
Coil pack is grounded, I'm getting spark. I did find a blown fuse after you guys mentioned it, it was the ECU/SOL fuse. I replaced it but didn't help. There is a 30 amp fuse that looks like it has melted some of the plastic and has pushed back the connection in to the fuse block a little. I'll have to look it up in the manual to see what it is for.
I've moved the cam sensor around here and their trying trial by error so much I don't even know if it is in the right spot anymore. I'll have to start from scratch and reset it. That fuse may have fixed it and I just need to set the cam sensor again but knowing these cars that is wishful thinking!!
Thanks again!!
