Guys i thought i had smoked my steel shim headgaskets and was leaking water past them (water was leaking on the ground). Now that the heads are off, i don't think so. When i removed the ARP head bolts (they were all still at torque), all but two headbolt shanks were completely wet with antifreeze. When i installed them in December i had cleaned the threads in block and used PST sealer on the threads, new ARPs and torqued to spec. I think the sealer failed to do its job.
Anybody else have this happen? What did you use when you put it back together and have good results?
thanks,
Mitch
thanks,
Mitch
