motor mounts
gn79
I was going to change my motor mounts, but when I looked under the car I found out that both are still there and good. I did find that the driver`s side motor mount is missing the two bolts. I was hoping to see if anyone kowns the size of the bolts. I am going to replace them torrow. The last thing is that the holes are lower than the mount. Can I jack up the mounter a little to get the holes right on the spot or is there any other way. Can someone help me out here.
Size of bolts in my original mounts is: 5/8" hex head, 7/16" diameter, 3/4" long. The motor can be jacked up a little if you loosen the long bolt in the other mount and anything else that might be in the way such as a tie-down strap.
