mounting fuel cell in trunk issues?
norbs
Classic fast, XFI, SPortsman & MS3 programming
Razor, what are the problems i am going to encounter here? The shuflo pump should be mounted where???????
On Cal's car he mounted the pump underneath the passenger rear seat. We havent put the system to run yet..ran out of time for the Reynolds evenet..
I dont have experience on the Buicks doing a trunk application on a faster car. Typically when I have done rear tanks, i've mounted the pump up front and ran the hose accordingly. Keeping the pump mounted lower than the tank so that its always gravity fed.
Vehicles in the 60's before EFI.. had fuel pumps mounted on the engine..
When I get some data on Cal's results.. i'll share..
Norbs
I have my setup mouned in trunk. The pump sits in part of a fenderwell beside and below a 1 gal tank. I had a custom braided teflon hose made up to run from the pump to the front. I just prime the system when I start the car for the day and she is good to go. Because the car is a hybrid and smaller, Razors kit fit without having to splice and extend any of the wiring.
Paul
