TOOMANYTOYS
- Oct 18, 2003
I keep getting little whiffs of antifreeze while driving. I see that the heater control valve has a very slight leak near the arm. Can I just delete this thing or do I need to have it?
SignUp Now!I don’t have a/c yet but I am planning on re doing it in the near future.
Does anyone have a part number for it? Everything I find looks nothing like what I have
Mine was seized up when I got the car but I needed the defrost. You can take the valve off and install a 11/16 inch male to male nipple, one-piece hose (what I did) or a new valve.
If you take the valve off, You will need to cap off the plastic vacuum line.
Heater valve is just that. Install a correct one and have heat and switched no heat, bypass it and have heat all time.
What little I have driven the car, I have not noticed anything different.
Move to AZ, you'll notice it....... It was 110 here today, 10th day in a row at 110 or above......![]()
What's having AC have to do with the heater control valve?It helps if you have and use the A/C.
He just explained it. It keeps heat out of the HVAC box when calling for ac. No need to heat and cool at the same time right?What's having AC have to do with the heater control valve?
There's a heater control valve even on non AC cars. It just opens and closes the heater hose valve.He just explained it. It keeps heat out of the HVAC box when calling for ac. No need to heat and cool at the same time right?
Yah, because there's times in he year when you might not want heat in the car, no? Maybe in the summer even without ac why add heat to the cabin.There's a heater control valve even on non AC cars. It just opens and closes the heater hose valve.
