MP Buick GN Powermaster Brake Conversion Kit?
TEEDOFF
Has anyone ever tried the Buick GN Poweremaster brake vacuum conversion kit(Part number BM8743)offered by MP(Master Power)Performance Brakes? If so, I'd like to know, the results you got(Good or bad?)? This is a complete, new, vacuum brake(Replacement) system, for 1985-87 Turbo Regal's and GN's. If anyone has experience with this unit, I would also like to know, if a vacuum booster pump was needed(To achieve the necessary vacuum)or, if this pump was not needed, for the kit's vacuum booster, to operate properly(Enough vacuum?)? The good part, would be if this brake kit, worked good(As is)without needing any additional brake optional accessories? The web site for this company is www.mpbrakes.com. I just found out about this system-so, I'd appreciate getting anyone's input on this? Thanks!
Don't know how much the "kit" is but most people just use OEM (or salvage) pieces off of a non turbo Buick. No supplemental vacuum source needed as far as I know.
Powermaster to Vacuum conversion
I just changed the Powermaster unit on my 87 GN. I bought a kit from John DiCarlo. It had everything needed, including good instructions. It's a pretty tough installation job under the dash, but mine works fine. John is @ Rudykz@cs.com.
