Msd 2351 wiring?
bpman1234
So I have it hooked up to to power wire at the sender but when the prime is done it doesn't get power key on engine not running .so what wire to the fp relay on passages side gets constant power key on engine not running.cause I have to make adjustments that way.just like the powerlogger.
I take back what I posted. The PNK/BLK wire at relay connection D is hot in run and crank, and off at key-off. I should have looked at the diagram first as the fuel pump power comes through the ignition switch. GM started to use a fused battery connection for this in other vehicles.
RemoveBeforeFlight
Anyone have pictures of it installed? Any details on how it was finally all wired up with the Hotwire kit?
