MSD 3 bar map
gn-geoff
BUICKS on the brain
Has any one used a MSD 3 bar map sensor on there GN,s.Or are they just for there equipment only.
Thanks geoff
Since the map sensor is used only as a sending unit for the boost gauge, I would imagine that it would work fine, just the boost gauge would be skewed.
X2 :D
Unless you run a PAC or SD set-up, hard to say.
Not sure about the calibration with PL either, but I am sure it will be close. (There is some adjustment in the readings :cool: )
Why not just get the GM unit to make sure it works with the aftermarket products? :confused:
Post a link of the unit.
You want to make sure the voltage reading at 0/0 is correct. :smile:
