MSD DIS 4 w/coil pack & MSD wires
turbobuick
Staff member
COmplete set up. Has DIP switches. WOuld be well over $600 for everything new. Has been 8.74:smile: $450 plus shipping.
What all is needed to do to install this on the car as far as wires go other then the obvious. And does it have RPM limit built in like a studder box? Sorry if the answers seemobvious to you but I don't know much about these!
Theres a positive and neg that should be hooked to your battery,And a small ground off the coil adaptor.
Other than that,just bolt it down,
They do have a rev limit and 2 step built in.
THere is also a wire you can use for security,Hook it to a switch and it disables the ignition
Hope this helps
Its a kick ass deal
Batterys in the trunk could I use the alternator stud and a ground on the fender? Why do some people dis-like these box's?
