MSD50 Injectors with Chips
No EGR delete on the chips. I can add that if you need it. Also, Wastegate code delete as well if you're using a stock wastegate.
I am thinking of going with a TA49 or a TE44. Would those injectors work with either turbo? Sorry for the questions still learning. I am planning on running EGR delete.
The 50lb. injectors are a great match for the upgraded turbo. I ran 11.40 with the 50's and a TA49 - on the Cobra.
That is what I am looking to run. Why would you do wastegate code delete also? Sorry for another question. I just saw these are sold already?
Yes, they're sold. Lots of PM's on the package, must have been a good deal :)
In answer to your question, some cars have an external, manually adjustable wastegate, so by deleting the factory solenoid, you set a code when it's out of the circuit. Removing the code eliminates the annoyance.
Thanks for the info. I was asking the questions to make sure I was going in the right direction because I wanted to purchase them.
