MT Slics 10.5 x 28
V8killR4U
Can you fit these under the car with no mods. IE will they rub or do you have to modify the wheel well. I just bought some and I was wondering if I was gonna be able to mounthem on my rims and just bolt them on?
If it helps, I have 28 X 10.5 X 15 MT ETD's on 8-1/2" W X 3-3/8" BS wheels with 2 bags on 2 TRs and they fit just fine...
I had to cut out the fender lips on both sides for mine to fit without major rubbing. I have 9in wide centerlines, not sure on the back-spacing, but I have less than a 1/4 on the inside on both sides. These tires look sick on the car but I wish I got a smaller size that didnt need fender mods
I run 28x11.5's on 15x8.5 Welds w/3.5 BS and they fit with a .5" spacer. No cutting or rubbing. You'll be surprised what will fit under a Buick with a little experimenting. I should be able to eliminate the spacers with aluminum brake drums
