MUST GO Built 109 long block drop in and go low 10's/high 9's
84gnolds
109 block 40 over JE pistons,plasma ceramic rings,comp cams flat tappet(112/112),K1 rods,Cat steel crank,BHj balancer,J/W wheel. All zero balanced
complete with oil pan,timing cover,w/p pulleys and brackets,
ported stock intake/fuel rail
ported stock heads with isky springs,cometic head gaskets
ported by percision porting
80lbs oil pressure cold,45 at 170degrees, runs cool,very street friendly
has no rockers-pushrods/injectors/tb-doghouse/valve covers
has been 10.2-10.3's on 20# at 135mph
on street tune-13lbs went 11.5 at 117mph
asking 3,500 shipped
or 3200 if you pickup
ready to run,just install your parts missing from above and go racing.
3,500miles 6-1/4 passes.
any steel caps or girdle? whats the real size of the cam? isnt the 112 the lobe seperation?
