built 109 motor complete step up(turbo/intercooler/electronics)
84gnolds
built 3.8 turbo 109 block
40 over je pistons(plascermic rings),K1 rods,cat steel crank,comp cams custom cam(flat tappet), harland sharp roller rockers 1.6,cometic head gaskets,double roller chain,percision ported heads/intake,isky springs/locks, bhj sfi balancer,j/w flexplate, steel mains,arp main studs,head studs,70mm tb, kenne bell doghouse,83lb injectors, Ls1 maf will include all piping and filter
ported headers,3" downpipe,PT70 turbo, deltagate wastegate 3" single exhaust,v2 front mount intercooler 2 1/2-3" piping to/from intercooler
10" coan convertor 3500 stall for th350 trans(built to match motor)
translater plus,ls1 mass air, extreme race chip, msd dis4 w/interface,scanmaster, 2 step
new alt/water pump
complete with pulleys, belt wiring computer etc drop in and run
low miles few passes went 10.3's on 20lbs
fresh fluids
nothing wrong with motor just going with differant set up
located in lancaster PA
make offer
pics avalible
