low 10sec built 109 motor complete/ misc(turbo/convertor/intercooler/electronics
84gnolds
engine: 3.8 GN block(109)
40 over je pistons(plascermic rings),K1 rods,steel crank,comp cams custom cam112/112(flat tappet), harland sharp1.6 roller rockers,cometic head gaskets,percision ported heads/intake, bhj sfi balancer,j/w flexplate, 3 steel mains,arp main studs,head studs,70mm tb,kenne bell doghouse,83lb injectors.
headers. runs good 80psi oil pressure cold 40psi warm runs 170 all the time. more built right,freshly serviced, has been 10.20/10.30 on 20#. runs 11.5's on street tune(13#'s) complete TB to pan:7000$ shipping avalible
PT70 turbo,turbonetics deltagate wastegate,manual boost controller
3bolt to headers 4 bolt on downpipe(700shipped low miles well taken car of)
coan 3500 stall convertor(350$shipped)
2 1/2-3" intercooler piping(painted gloss silver),V2 large front mount intercooler (500$ plus shipping
translater plus w/ls1 maf(250$ shipped)
computer w/extender extreme race chip(83lb injectors tuned by(bob bailey)(25degrees timing in rev limit)100$ shipped or maybe include with motor
msd dis4 w/interface(complete with coilpack and wires.(450shipped(with instructions)
lm1 wide band w/new o2 sensor(250$ shipped)(with intructions)
scanmaster 2.1:(150shipped)
all prices not set in stone.
717-669-2606 motor still in car
coan convertor
1st in line on the convertor pls. Can you pm me more info on it, ie.... miles, lock up/NL, part # possibly, balloning plates?, 10"? and it is for a 200r4 correct?
Thanks justin
scanmaster
2nd in line for scanmaster please if the deal falls through
convertor is for th350 trans 10" antiballon plates cost 600$ new 3,500miles on everything
