Reserve & buy now lowered to $25,500.
My rock bottom price.
Link to car on ebay:
eBay Motors: Buick : Grand National (item 180168661457 end time Oct-21-07 10:26:25 PDT)
1987 Buick Grand National - 63,000 Miles
2nd owner. Carfax available upon request - clean! Partial frame off restoration. Everything new at 52000 miles, restoration fresh in 2000.
Professionally Rebuild Engine: 3.8L LC2 Block
Stock Rods-(Reconditioned)
Stock Pistons-(Reconditioned)
Stock Crank .010 under
Block Decked and Cylinders Honed
Line Bore for Girdle
Modifications Include:
RJC Girdle W/ ARP Studs
Melling High Volume Oil Pump
Braided S.S. Oils Lines W/ AN Fittings
B&M Oil Cooler
New Oil Pan
Heads:
Special R&D Factory heads W/O EGR Ports
ARP Studs
Ported and Polished
Stock Valves & Seats
New Seals
Cometic Stacked Steel Shim Gaskets
Valves Reconditioned W/ Three Angles
Champion Roller Valve Covers
Valve Train:
T&D Roller Rockers Arms 155 Degree Lift
Comp Cams Roller Lifters
Comp Cam Roller Cam Shaft 206/206
Double Roller Timing Gear & Chain
Fuel System:
Stock Lines
Applied Technologies Dual Pump RP354-6P
#60 Mototron Injectors
Billet Adjustable Fuel Pressure Regulator
Stock Fuel Rails
Intake & Throttle Body:
Stock Ported & Polished
Port Matched to Heads
S.S. Bolts
3” Coated MAF Pipe
MAP Converted (NO MAF)
Ignition:
Stock Coil Pack
Magnacore 8MM Wires
Stock Plugs
Exhaust:
Terry Houston S.S. 3” Downpipe W/ Dump
FJO Wideband O2 AFR Sensor & Gauge
Greddy Profec B Spec II Boost Controller
Turbonetics Evolution Waste Gate
Hooker Duel Exhaust & Chambered Mufflers Jet Hot Coated
Stock Headers Ported and Coated W/ S.S. Bolts
Precision PT 61 Turbo Extreme Heat Coated
Mease Powder Coated Stretch Intercooler W Aluminum Scoop
Transmission:
Stock 200 R4 Rebuilt
Art Carr Shift Kit
Art Carr 9” Converter 3200 Stahl
Chassis:
Stock Rebuilt
Boxed Rear upper & Lower Control Arms
Stock Gear
PST Urethane Graphite Bushings
Painted
Body:
Custom SUPER Straight Paint PPG Paint & Concept Clear Coat Color Sanded Show Quality. Black chrome beauty! Must see to really appreciate.
This recipe, so I've been told by my "GN professor" will produce a 10:90 car on slicks, C-16, 20+ PSI and tuned. I've not tested it however.
Must sell due to upcoming college tuition for our oldest.
Reply here or through the ebay link for more info and/or questions.
Pics on ebay and: DSC04970 on Flickr - Photo Sharing!
Thanks.
B&M Oil Cooler
New Oil Pan
Heads:
ARP Studs
Ported and Polished
New Seals
Valve Train:
Fuel System:
Stock Lines
Stock Fuel Rails
S.S. Bolts
3” Coated MAF Pipe
Ignition:
Stock Coil Pack
Magnacore 8MM Wires
Stock Plugs
Exhaust:
Transmission:
Art Carr Shift Kit
Chassis:
Stock Rebuilt
Stock Gear
Painted
Body:
Thanks.
