SignUp Now!I think there used to be; its somewhat disjointed now. I know for sure there are at least 3 or 4 guys not far from me. Happy to host something at the house.
He is running pretty much the exact same Wheel / tire /brake set up as I am. Those LS1 brakes don't even compare to this set up! The rear is a 4-piston caliper and mine is lowered 2" front & rear without a single issue with the caliper touching the frame and the caliper is no where near the inside rear lip. You can reach through my wheel spokes and actually touch the caliper. Here is another BAER brake install thread where it shows some of those clearancesWhat a great looking car, & awesome overall package. Nice work on the brakes & thanks for sharing the pics.
Question, the caliper looks fairly thin on the backside, would there be any worry of any parts contacting the frame if a car was very lowered in the back? The calipers don't look anywhere near as big as the LS1's do, do they stick out past the backside lip of the wheel any?
I think your car/setup has just convinced me of my next mod, keep up the good work!
Correct!Thanks for the reply scott, I was kinda hoping you would jump in on this.. I am mainly talking about the rear setup. It seems like this setup doesn't have the frame/caliper clearance issues that you run into using factory parts when the rear is lowered.
With regarss to the Ebrake, did you eventually get yours installed & what was involved in that? I haven't seen anyone post info on that side of things.
