- Nov 4, 2005
ok i did some research and i cannot resolve why my tach/boost guage is maxed out.its the stock analog unit,also my car is an 84 with an 87 drive train,the tach is maxed out,the boost gauge moves like it is the tach...
i checked to make sure the fuel pump prime and tack connector wasnt pluged together.they werent.
i have an 87 ecm and installed it and no change..
i have two other clusters tried them and no change....
does all three clusters need "recalibration"?if so im an electronics tech,whats involved in recalibration?i read some chip(s) needs replacing?
could this be any other problems??(i know the inside harness wasnt changed because i traced back another problem(my fan relays werent getting +ign,found the firewall plug had an different pin arangement)
once again , thanks in advance for your knowledge... Gary
