Details of the run:
60'-1.827
330'-5.086
1/8-7.870
MPH-88.09
1000'-10.284
1/4-12.345
MPH-108.96
Screen Name or Car Number Here: TTA 1546
EMPTY WEIGHT: Stock with Kenny Brown SFC's (scales were closed when I tried to weigh in)
BLOCK: Stock
HEADS: Not totally sure
CAM: Not totally sure
TRANSMISSION: Stock rebuilt
TORQUE CONVERTER: Stock 2200 stall
DIFFERENTIAL: Stock
INTERCOOLER: Stock TTA with dutt neck
THROTTLE BODY: Stock
RJC POWER PLATE: Yes
INJECTORS: 60 lb Hi-Z
THERMOSTAT: 160
TURBOCHARGER: Stock
VALVE SPRINGS: 100 lb.
MAF:stock
DOWN PIPE: Mease 3" with dump open
EXHAUST: ATR single 3" shot
FUEL PUMP: Walbro 340
FUEL PRESSURE REGULATOR: AFPR
FUEL PRESSURE: 43-45 line off
ALCHOHOL INJECTION: Razors PAC!!!!!!!!!
PROPAIN INJECTION: No
NITROUS: No
AIR FILTER AND AIR INTAKE: ATR MAF pipe with K&N in fender
TIRE DESIGN, SIZE & AIR PRESSURE: 255/50/16 BFG DR's 22 PSI
AIR BAG(s): NO
SUSPENSION: Street and Performance LCA's, Kenny Brown SFC's
SCAN TOOL: Scanmaster, Caspers knock gauge, powerlogger
FUEL: 4 month old 91 octane Walmart gas
CHIP: Turbo tweak alky chip
CHIP TIMING: 22.9/20.8
KNOCK RETARD: 0.0
OXYGEN SENSOR VOLTAGE: .798-.810
EXHAUST GAS TEMPERATURE: Good question
TRACK ELEVATION: 900 feet
TEMPERATURE: 92 degrees
PEAK BOOST: spiked 22 at the 2/3 shift 19 PSI the whole run
BOOST AT LAUNCH: 4 PSI
MILES ON THE CAR/ENGINE: 60,009
Just a note I made 12 passes in two days in hottttttttt weather. I was having trouble keeping my boost up as the heat was killing me. IAT's on this run (air filter IATS) were mid 120's. During the week I saw a low of 95 at 10 AM and a high of 135 at 2 PM. The alky worked wonderfully and I saw 2.1 degrees of knock on the 2/3 shift one pass. Not sure what happened but it went away so fast I didn't get out. Must have been false. I used exactly 1 gallon of alky for 12 passes so about 10 ounces of alky per one pass. Seems awful high but the turn on is 4 PSI and the knob is at 6. Maybe some evaporated? Who knows.
I tried turning the timing up but for some reason I have a voltage drop at startup erasing all my settings. Overall I had a great weekend. I plan on going out to the Buick versus Ford event in Noble, OK October 27th for some cooler air. Maybe after brake pads, more timing, a little cooler air, and a little leaner, I can get that 11.9999999 pass or 110 in the 1/4. Those are my goals for the moment.
Thanks for reading,
Jason
60'-1.827
330'-5.086
1/8-7.870
MPH-88.09
1000'-10.284
1/4-12.345
MPH-108.96
BLOCK: Stock
DIFFERENTIAL: Stock
THERMOSTAT: 160
TURBOCHARGER: Stock
MAF:stock
NITROUS: No
AIR BAG(s): NO
KNOCK RETARD: 0.0
Thanks for reading,
Jason
